Piston Compression Question - Boost Forum
Friday, December 29, 2006 6:49 PM
I am turboin my cavalier 2.4l and i want to know wat kind of pistons i can get
Re: Piston Compression Question
Friday, December 29, 2006 6:58 PM
Gee thanks for the info...
Maybe some info on your setup would be nice, and maybe what your goals are...
Friday, December 29, 2006 8:29 PM
i want to get turbo, new pistons, rods, and sleave my block and cams with 10 psi. want to know what kind of pistons are good for turbo.
Friday, December 29, 2006 9:22 PM
Goals?
Turbo size?
Cam specs?
Why sleeve your block for 10psi?
How good are you at tuning?
What octane gas are you going to use?
What are you going to use for tuning?
Saturday, December 30, 2006 3:39 PM
Sounds like this will be your first turbo setup?
If so boost the stock motor for a while. Work out the bugs, learn how to tune, get used to the car boosted. Then build a motor.
2.4s are a closed deck block no need to sleeve for quite a while. The 2.4 block is one of the stronger points of the motor.
- 97 Z24 Racecar work in progress
- 04 WRX STi
ATR Crew Member
Sunday, December 31, 2006 8:23 AM
Atomic wrote:Sounds like this will be your first turbo setup?
Sunday, December 31, 2006 11:56 AM
will a stock 2.4 motor be fine with a turbo on it and how many psi should i run
Sunday, December 31, 2006 4:42 PM
you should research that and then post it here... look for how much horsepower your engine can handle with a stock long block, not how much boost.
Monday, January 01, 2007 5:36 AM
I heard 250 at 7psi.
Monday, January 01, 2007 10:55 AM
you could have 250 at 15psi or 5psi or 20 psi... every setup with yeild different results.... so the highest safe hp to go to on the stock long block on a 2.4l is 250hp you are saying... interesting... i have a lot to read up on now that my good friend is turboing his jbody (he has the 2.4l)
Friday, January 05, 2007 3:13 PM
^^I read that somewhere on here looking for something else I cam across it...
Friday, January 05, 2007 4:17 PM
I hit 240hp/280ft-lbs at 7psi on mine. I know people running much more.
