Quick question, I am looking around 10-12 psi of boost for my 2.4. Now I have gotten some S/C injectors, and looking to get a FPR and a new inline or intake Fuel pump, should that be enough fuel for what I am looking for. I am eventually going to get HPT, but until then would this set-up work? Also can I use the s/c injectors without the reflash? Thanks
New Sponsors: Show Stopper Tuning, Turbo Tech Racing, Izn Trbl Inc.
you definitely need 370's or 440's with an intank fuel pump to push that amount of fuel.
what are the S/c injectors rated at?
also if I just use an inline pump instead of a intank? and can I use the s/c injectors with my stock ecu?
S/C Injectors are 310cc.
Bobby(Blown&Pullied) wrote:S/C Injectors are 310cc.
thanks. and can I use these injectors without the s/c reflash?
Yea you can use them without the reflash. I did.
thanks
with my s/c and the 310's i was running lean , low 13's under full boost up to 7psi
i went with 36lb injectors , and now i can in a good range , currently mid 11's
i wouldnt use the s/c injectors over 3-4 psi
so why did gm include them with the charger that runs 5psi??
2000 Camaro V6.
because they kept the tune with alot less timing
even off boost timing was droped , alot of my timing tables showed retarded timing , not advanced
the gm kit is 4.5 psi so the 310s can handle that, they really are maxed out at 4.5 though
