I see that the hahn stage 2 kit which I will be ordering this week for my ecotec cav has a different type of intercooler? The inlet and outlet are on the same side of the intercooler? Is this a bad or a good thing or neither? Should I consider buying a different one down the road or is this a good intercooler? thanks.
2005 LS Sport Coupe
well, i didnt know at the time, but when i bought it and installed it, i couldnt get my windshield washer tank or my bumper back on because the drivers side foglight was hitting the charge piping. so i had to remove the drivers foglight, however, i have modified that foglight and am looking forward to putting it back in. just gotta find out how to mount it.
its the way the charge piping is run with the kit. its more then enough of an intercooler to support a mid to low 11 second 1/4 mile so unless u plan on making over 500hp. it will be fine
http://www.myspace.com/15102113
thanks for the replies, still going with the hahn kit...thanks
2005 LS Sport Coupe
Look at the times I've run with the kit....enough said.
Contact me when your ready to order. I may be able to save you a little over going direct....and you'll be helping a fellow JBOer out.
5K PB: 24:50
10K PB: 54:26
K I will keep that in mind...thanks
2005 LS Sport Coupe
