on the 2.4....what size fittings are used to the top of the motor where the oil sensor is and what size do u use after u drill the pan out.....im using -3an feed line and -10AN Return line if that helps at all...thanx in advance
you scratch my ride IMA EAT YO CHILDREN
Well the oil sensor and hole that is left there when it is removed are 1/4 pipe threads.
ok thank you...and watabout on the oil pan what size fitting should i use on that
or is there a way to get around drilling the pan on a 2.4?....
