hi everybody! i actually run a ebay turbo on my car! not an xs power its a no name one... but this is my second turbo i bought from the seller and the same problem happen to me.. the turbo take a lot of oil!!!
juste check that video to see what i'm talking about
http://videos.streetfire.net/video/958f45c4-f876-4373-a202-987c011be4be.htm
Is there a secret??? is these turbo crap?? i wanna know if i can do something to fix that or spend money for a real brand turbo...? i'm running 10W30 oil and I have a restrictor (1/16") in the oil feed line and the return line is direct through the oil pan!
any comment, advice or solution ??
http://cavalierdomination.monchar.com
video no work for me
you scratch my ride IMA EAT YO CHILDREN
What is this video showing? I saw you drive away
Its your turbo smoking, most likely your oil drain is not sufficient. When the turbo spools up it burns the oil. Make sure your Oil drain is at least 1/2"
I did not see blue smoke. To me looks like it is cold and that is the exhaust showing in the cold, but maybe that is me.
I think you need new struts. And yeah, if you wanted to show smoke, you should have waited for the engine to warm up. It's hard to tell in that vid.
the engine was warm! i only stopped the car few seconds before I start the camera
and yes this is blue smoke!! when i floor it, it's smoke a lot more
either oil return, or you are pressurizing your crankcase.
idk about cavalier, but when my rotary would smoke blue, it means that my internal oil seals are going out or are out.
I'm curious did you ever find the problem? It sure looks like its burnin oil in the vid.
Thank you Captain Obvious.
