Just to clear things up. If you want to get the reflash for 2000-2002 LD9 2.4 Supercharger and dont want to spend over $100 for a map sensor, You can buy a MSD-2312 TWO BAR MAP SENSOR . I just put one in my car and it works mint. The price is only $40.88 and $9.95 Shipping from
Summitracing.com. I also bought a MSD-8172 CONNECTOR 3-PIN WEATHERTIGHT Connector which was an additional $8.88. You have to modify it a little to get it to fit into the sensor. You only have to cut 2 grooves in it to make it fit. You can do this with a razor blade. This is an excellent alternative to buying the GM 2 bar map. And if you ever need to replace it it is only $40.88.
Thanks for the info.
Most excellent, thanks for the info.
2000 Z24 5spd header & catback for now.
FYI, AS4 is the standard part # for the 2 bar map, as well as Delco# 213-1520.
I just bought these parts the other day after about an hour of searching...It's funny I'd see a post about it here. Just thought I'd share.
does the msd 2 bar map sensor bolt right up?
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Publikdstrbnce wrote:does the msd 2 bar map sensor bolt right up?
doesnt bolt lol...yes it plugs in to ur manifold by way of vaccum line
you scratch my ride IMA EAT YO CHILDREN
back from the dead....would I be able to use this with an ecotec?
or, just use a GTP 2 bar map.. Not sure if it plugs into the eco harness though.
Cavgold96 wrote:Publikdstrbnce wrote:does the msd 2 bar map sensor bolt right up?
yes, but its got a little bracket that bolts it to the TB as well. does the msd come with it?
no I dont think the msd does
Bringing this one back.
Does this msd use the factory connector or you have to buy a different connector and splice it in? I also see they jacked up the price on this since it was originaly posted lol.
