What wire do i need to use, i have a dyno in the morning and need to know.
Pull the coil pack cover off, and see if you can get a signal from one of the coil packs.
they use the inductive pick-up , and it will prob take a couple times , but put the pick up around a couple of the wires going into the coil cover
no need to take it off
Pink wire. Another wire can be used also. I forget if it's the black with white stripe or just black. But clamp the pickup around that wire and change the ignition settings in the computer so it reads the correct rpm.
when i went to get dyno'ed they just hooked wires until they saw the right rpm on the screen....
