Ok i Know the internal of the ecotec 2.0 supercharge are stronger than those for a 2.2 ecotec... the question is can I use a 2.0 block and put my 2.2 head on it? Maybe I could get a 2.0 ecotec engine for a cheap price so this is why i'm asking the question!
http://cavalierdomination.monchar.com
Same block. Just different internals. Your better off just buying another 2.2 and building it up.
5K PB: 24:50
10K PB: 54:26
actually the block is different too , the crank sensor location if i remember right
plus the 2.0 has theengine oil cooler
you can put a 2.2 head on the 2.0 and visa versa
money is well spent on internals for the 2.2
Then use the oil cooler and call it good
Crank sensor shouldn't be in a different place since it's the same crank design.
5K PB: 24:50
10K PB: 54:26
sensor is in a slightly different place , from what suncavi said , also the crank wheel is different , and the sensor reads at a different rate
Interesting indeed.
5K PB: 24:50
10K PB: 54:26
why does everyone want to use a Jbody pcm? if your running a LSJ, get the LSJ pcm, if your running an L61 use and L61 head, theres not much thats swappable between these motors
electronic throttle body maybe? thats my only guess
http://www.myspace.com/15102113
Because the LSJ computer is completely different than the L61 computer and would require rewiring of some major stuff. Maybe that's why. Just an obvious observation.
5K PB: 24:50
10K PB: 54:26
why does everyone bring up the throttle body? Just use an L61 TB on it or get a gas pedal from a cobalt, I dont see where the problem is its a whole lot easier than trying to run the car off a j body pcm, rewiring is a part of an engine swap , if dont want to do that, dont do it at all
