nice idea but i'm almost positive the way you have it set-up won't pass any intelligent tech at the track.
you crackhead. Might work okay for an NA motor, but any boost or a nitrous backfire will blow those injectors right out...and then your car is on fire
fortune cookie say:
that doesn't look safe to me
id be worried about those hoses cracking or somehting
I may run 18s, but I can do your taxes in 10 seconds flat.
wow! That set up takes some serious guts!! lol, i would be scared to start the car
omg don't do it, there is soooo much wrong with that. Those lines will in no way hold the pressure nitrous sprays at and im not sure those injectors will stay in for long either. That setup requires hardline like a direct port and tapped manifold man.
"Horsepower is the Ultimate Accessory"
why would it not hold pressure? it looks like fuel line to me...... but i prolly wouldn't do it that way myself. how are those injectors securely mounted??
I don't have a problem with using fuel line (hey, it's called 'fuel' line for a reason lol), and he's not running nitrous through those lines Jimmy.
It's the fact that there's nothing solid holding the injectors in position that has me worried.
fortune cookie say:
OMG...........................................only on a j-body....................................
Hey, Russ is here, party. You still have your LN2?
fortune cookie say:
^^ Wow i haven't seen that name in a long time.
nope....woke up one day, figured what the hell am i doing???!!?!?!?!!
parted it out...still have the motor though......bought a 67 firebird, to turn into a "resto mod", and a 92 GTA. I've developed a real LOVE for the LSX's
So, are you going to tell us what you did to that motor now?
I don't blame you on the SBCs, just a
little more potential there lol.
fortune cookie say:
the injectors are just temporaraly in there there going to be jb welded in
http://www.cardomain.com/ride/2090440
make a plate to hold them down or something...jbweld will break over time.....
this place is a giant hill of @!#$. people throw a litlle and that gets it started and people just squat and wait for it to pass by.
Kick azz is my boost hero!!!
pleeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeease make a bracket to hold them in. dont jb weld them. spend an extra 20 bux, and do it right.............................
Yeah, I agree with Russ.
It's a novel solution, and not bad either. But even the OEM injectors have a retaining plate to hold them in. Mount the fuel rail securely (I'm sure you're planning to do that) and put a little clip on each section of hose from rail to injector if you can, and the setup should be fairly stable. I've checked with the Oracle, and it says "Bad things to come with JBWeld holding injectors in." The gods of fire and destruction thought it was a nice idea, though.
You might even be able to use the OE injector retainer with some mods.
And a small history lesson for a few others. Many Euro cars reliably used injectors with hoses attached to the top instead of a rail.
-->Slow
Dont jbweld them in. Think of it this way... You're injector fails, what do you do now?
slowolej wrote:Yeah, I agree with Russ.
-->Slow
exactly.....its not the hose thats scary....its the way its connected. not just asking, but BEGGING for a fire......
I'd grab a fire extinguisher before driving too far with that setup.
its all temp. i just was happy to see that it all worked...
Nitrous Nate wrote:its all temp. i just was happy to see that it all worked...
Please like everyone else said, secure the injectors in the manifold before they pop out. I've seen injectors pop out of a manifold when i was dping some testing with my setup removed from the manifold. I had the injectors spraying into the air to test spray pattern, and one would always pop out after like 3 seconds! So, please secure those. They are probably at the limit of that red silicone looking stuff that is holding it in there. Also, why JB Weld, what if you wanted to upgrade injectors in a few years.?
i actually have 3 intake manifolds lol all bored out and ready for top feed so jb weld is not a problem... just swap all of them in out...
