ehy guys,
I recently got back into jbodys ( i used to have one a while ago) and It's a 98 z24. The guy that i bought it off of said they put a motor from a 2000 z24 into it. My question is how do i konw if he is telling the truth. Is there any way to tell if i have a pre 99 or 2000+ motor? thanks alot. any input is appreciated. ( reason im asking this is because i plan on charging it with the gm charger and i want to know if i can just get the kit and be ok or if i have to do all the work to make it work. ) thanks again
"Boost tuning"....... have you had your 8 PSI today?
future name of the winter shop!!!
Look at the head, between the cam towers, there should be a part number.... 99+ uses a different head.... or is it 00+ I am not 100% sure right now... sorry...
Karo (Car Customs) wrote:Look at the head, between the cam towers, there should be a part number.... 99+ uses a different head.... or is it 00+ I am not 100% sure right now... sorry...
here's the part number breakdown, in this thread:
http://www.j-body.org/forums/read.php?f=30&i=33609&t=33607#33609
Desert Tuners
If he used a 2k+ motor, but kept the 98 ecu, you'll still have the problem of not being able to reflash it. Don't rely on the EGR being there or not, you can add an EGR to a 2k+ motor, the hole is in the head, you just have to pipe it. I'm betting he used the 2k+ block/head, but kept the 98 accessories (intake manifold, exhaust manifold, ecu, etc). This would mean that putting an s/c on it would be the same as any other 98.
Boardorgohome wrote:you are a pussy tom, get a turbo
HAHAHAHAHA... thats awesome
Scott
Check the knock sensor, 1 wire-96-99, 2 wire-2000+
shut up sean lol. at least my car runs......
theres nothing wrong with a little ring gear slippage
can still have 2k+ motor and use 96-99 knock sensor just have to drill it to fit i have a 2k motor in my garage with the 96 knock sensor in it, another thing on the heads my 96 has square depressions between the ports where as my 2k head if totally flat between the ports
