ok so what is safe to run through the basic coolingmist kits hoses?? anything BUT alky? im using windshield washer fluid right now.....i know i should be using heet and water....but is there any other stuff out there that works better?
2000 Camaro V6.
I have run straight water, 50/50 alcohol/water, straight alcohol, and washer fluid I found that the 50/50 alcohol water works best. Its like $8 for a gallon of denatured alcohol. this makes you 2 gallons. To answer your ? there will be no problem running just about anything through those lines.
