As the title says a friend of mine just gave me the M90 off of his GTP ( he went M112) and I have a 2000 Z24, does anyone make or sell the intake manifold separately and will the M90 bolt right on to it?
I'd rather not have to buy the entire sc kit just for the intake.
2000 Z24 5spd header & catback for now.
If you can find room for the m90 under the hood you may have to build an adapter to convert the m90 output to a pipe and put it pre intake, we tried post intake with a sheetmetal intake and the problems we had were great. The engine simply ran like crap, and i couldnt get any of the tunes on tuner pro to work.
Part of my problem on the 2.2 is engine bay room and runner length,i just couldn't make it work, on the 2.4 you may be able to make it work if you build a sheetmetal intake that resembles the gm 2.4 sc for your engine.
look up combatphil on quad4forums hes in the process of making adapters for the twincams and 2.3 motors to fit the m62 and m90 chargers. only thing is your going to have to remove your a/c and i believe hes making a adapter to relocate the alt.
24psi on the stock pulley...better get some head straps LOL J/K
go to combatphil, he's got the "mooseknuckle" to fit the M90. no AC can be used and the alternator sits in the AC compressor spot. I'm going with his setup as well.
^^^ yea i forgot to say that about the stock pulley
I don't mean to jack the thread, but i have a M112 at work just sitting under my bench..the end bearing are noisy but can be fixed..ne-waz, would it be possible to fit the M112 in the spot the M90 would be mounted??
good luck ever spinning that mp112 properly, or better yet, stock motor goes BOOM
Z Speed Cavi wrote:look up combatphil on quad4forums hes in the process of making adapters for the twincams and 2.3 motors to fit the m62 and m90 chargers. only thing is your going to have to remove your a/c and i believe hes making a adapter to relocate the alt.
Link? It's too bad you can't retain AC like you can with the GMSC kits. Is this design intercooled, or direct to intake manifold?
I can't seem to find a combatphil under the user search on quad4forums......
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
