Anyone know where i can find a good turbo kit for my 2.4l
be prepaird to be flamed with the "search" and seeing that your sorta new, fill out your registry so we know what you drive.. it makes a difference, here are a few good ones.
j-tuners.com
hahn racing
**changes are here**
Umm only J tuners thats all they sell now hahn does not have a turbo kit for the 2.4L Quad four. also if you have an auto be prepared to do som fabing becuase i don't believe these kits are based of an auto tranny. Hoping yeah the stick or you might blow up the tranny any ways during boost.
Do some research first on how turbos work and how everything in the kit works together to make more power. Then do some more research. Then talk to some people with the same engine as you and see what kind of setup they have, and find out what works and what doesn't. Then do some more research.
Then, when you think you're ready, piece together your own kit, buying individual parts instead of a pre-made kit. It'll be cheaper than buying a pre-made kit plus you'll have more options on things like the fuel system, ignition, etc. Pay a visit to the classifieds section on this site...I know once in a while someone wants to get rid of a complete kit, or you could pick up some good used parts for cheap. Do everything right the first time and you most likely won't blow up your engine.
I don't think you can turbo a 2.4... GM put in extra rear bearings to prevent installation.
ge_forcez22 wrote:I don't think you can turbo a 2.4... GM put in extra rear bearings to prevent installation.
lol...
you could always build a kit your self and buy all of the parts you want... you might save money, you might spend more... depends on your shopping, but you will definitely get exactly what you wanted...
sorry, I had to
