2.7 pulley installed much better take off.... but then again I lost alot of torque because my compression is 9.0:1 instead of the stock 9.5:1
I just ordered the 2.6 pulley and the alky should be here anyday.
Sorry...
You have been banned from posting on this site as of 2005-09-21
00:33:32. This ban will expire 2005-09-28 00:33:32 Pacific Time.
Reason: Comments over the top regarding Jordan Kruger and other members in Versus. Also, if you have a problem with a member e-mailing you, do not bring it into the forums.
If you believe this to be in error, please contact us.
so thats why you where not at the albany meet friday.
nice, my CR is 9:0 cause im gonna be spraying the 65 and 80 shot once, you should do the same if youve lost alot of power you think.
sinrocker wrote:2.7 pulley installed much better take off.... but then again I lost alot of torque because my compression is 9.0:1 instead of the stock 9.5:1
Stock is 9.7:1 on your year
>>>For Sale? Clicky!<<<
i thought it was 9.5 but what ever it is 9.0 now hehehe.....
the pulley read 6psi in hot humid weather, and the other night it was 55 and dry out and i read 7. the 2.6 pulley will be on in two days
Sorry...
Why did u lower the compression if you went s/c? We know that it can only max out with the 2.6 pulley to produce 8-9psi, maybe 10 in cold weather. So you'll never have as much power as a stock 2.4l motor. I was thinking of bumping up my compression a little bit on my spare motor. Anyhow, other then going no2, whats ur reasoning for lowering the comp.
Nate
1995 Cavalier W/2k1 Engine
bigger boost plans in the future...... i am already on the 2.6 pulley. the exhaust is going in next week.
i am running good i ran one of my friends in a saturn ion and i was only a car length n a half behind him by the time we hit out quart marked on the street
Sorry...
i need to verify from the machine shop if that was what was done..... because i also remember hearing from him that i had a milled head
so i may very well have higher comp everyything else listed is a fact i will update as soon as i get a chance to speak to them
Sorry...
I lowered my compresion because I am a dumbass and have 4Gs into a motor that runs NA numbers with bolt ons.
NO ONE SHOULD EVER LOWER COMPRESSION WITH THE GM SC!!!!!!!!!!
I am going to pull my motor and replace the pistons with higher compression ones. Sucks because I did all this work and the car is a dog. Or I might just park the damn thing and buy a better car.
Anyways, have fun with the boost, you must be planning on swapping out the gm sc for a turbo or something. That would be the smartest thing to do with your current engine set up.
Chris Fontana wrote:I lowered my compresion because I am a dumbass and have 4Gs into a motor that runs NA numbers with bolt ons.
i have 9:0 CR and mines not a dog, i lowered mine because ill be tuning for the 65 and 80 shot of nitrous here soon.
