i have a 96 z24 with 88,000 miles....im really wanting to install a gmsc ,my question is will it affect the engine in any way....as far as installing it without doing any sort of rebuilding internal wise. will it be ok? any one ever do this?
ClassGlass / RkSport / Eibach / Motegi / Ractive / Borla / K&N
i have 104k when i boosted my 2200
..no problems yet but i don't expect it to last
Edited 1 time(s). Last edited Friday, July 14, 2006 9:10 AM
i put the s/c on my cav at 100,000 miles , still going strong at 110,000
S/C on my 01 Z at approx 100,000 miles, some minor issues with the trans but nothing major. Good Luck!
the car is still 10 yrs old.
Shifted wrote: 88k on a 96 is an extremely low milage, not high.
really? i thought it was high, i have about 86k on my 96 z...
aslong as the motors been taken care of i dont see a reason u cant boost it... id like to boost mine, but no $$$
ayo 8 Iz Enuff
Honestly... if you blow it up then replacing the engine really isn't all that expensive.
Less than a grand for another engine from the wreckers right? So as long as it's not your only car and you can afford some downtime... you really don't have all that much to lose.
I put my turbo on around 85,000 and I am running 12 psi no problem. Remember I have a really good tune with HPTuners and bigger injectors.
Most ld9s around here cost roughly 400-600 with low miles (yards)...Im in texas.
also it will be the poor tune and lack of fuel that will kill the motor first
also get a wideband o2 , before you even start putting boost on it
not boosted, but plan on it, 92k on my 98..
The whole milage thing is kind of a joke. Milage doesn't mean that much. If the car was taken care of, then your going to be just as good as the guy who didnt take care of his car for 2000 miles. The one key to knowing if you car is boost ready (or at least the only thing you can check) is the compression. Good compression and you should be good to go.
I have around 120000km's on my 2200.....
read sig........
compression is key.......... if the compression is good, and overall the engine hasn't given you trouble.... your good to go .....
Lee
JDM Civic Hatch
