Hey I have a 00 cav LD9 I am undergoing a build and i was wondering what internals i should go with. For pistons I would like to go weisco, my cylinders are scalded really bad due to overheating ,girlfriend ran it hot
and cracked the head thats why i am undergoing this, anyways the cylinders are probably fixable but i figured i would just go with .020 mm oversized or would that not be a good idea? I was thing of the eagle H-beams for rods stock length. im not shure what head gasket i should use. I am running a GM supercharger but i plan to get a 2.5 pulley and coolingmist setup so is this the setup i should go with or does anybody have any suggestions for me?
00 Z-24 S/C
http://www.cardomain.com/ride/2159309
even without boring it out you can run 10:1 compression.
runing the 2.5 pulley on the s/c is not a good idea unless it is ported out cause you will just be pumping in hot air irregardless
Go with the 2.6" pulley with alcohol injection. You won't gain anything by going to the 2.5" except overdriving the s/c and having crazy boost spikes. The 2.6" will make just as much power without the danger of spikes in the boost.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
you really need to read up on all of this, dont make fast decisions on all of this.
