ok. so i have an appointment on wed to get it reflashed. i have the new 370cc injectors in, the map sensor and clip.. the car starts, idles and dies. i can tell there way to much fuel . what did u do before u got it reflashed? my car wont even move.
unplug the map.....and drive it in w/ out the sensor plugged in.
Eric drove his 20 some odd miles w/ the sensor unplugged, so did chad
just dont get on it. keep it below 3000rpms
the thing wont even idle. did u just unplug it from the manifold? cuz everythign is already wired up. i followed that diagram you posted about 2 months ago. the 370's are in
i know do not hit boost till its flashed. i have about 30 minute freeway drive for mine. i have an appointment on wed.
also, what fuel pressure do the 370's idle at?
mine acted the same way.....i wired in both connector ends...stock and tmap. i drove around with the stock map plugged in, got the real reflash, then just unplugged the stock map and plugged in the tmap.
did you have teh 370's in? i was under the impression it was too much fuel that was causing this... not the map sensor.
so unplug it completely and have a vaccum leak ? just tryin to make sure
sorry i dint make it clear.............unplug the connector from the tmap. leave the tmap installed just dont pulg the connector into it.
UNplugged
just unplug the connecot from the tmap
whats that a picture of? thats not the map sensor?
and when u say tmap, your refering to the new map sensor correct?
yes........it was just a picture of something unplugged.
As simple as i can put it, unplug the connector from the new map! Thats it
thats shoudl be it.
haha. well that worked.. runs pig rich but it works. so just plug it back in after the flash?
can u tell me with the vci number is snowman? the dealership doesnt have that much of knowledge on this... the guy i talked to said he would have to make some calls.. figure it would save me some hastle.
can u pm me with the vci number?
oh and btw, what fuel pressure should the 370s idle at?
thats a laptop hinge.
looks like a gateway hinge lol
"Growing old is mandatory. Growing up? Definitely optional."
cant help you w/ the vci sorry. I got in trouble for helpin NJHK. SO im sorry but i cant help you.
my advise would be to go to a dealer w/ knowledge of the supercharger kits, either 2.2 or 2.4 and make sure its a gmperformance parts dealer.
as for fuel pressure i know brandoson tld me he had it @ 37psi but he said he wouldnt recommend it. im runnin 46psi on ine but have yet to take it for a real all out sprint.
i would just set it @ 50 psi and then make a run and see how your afrs were.....then lower/raise it as needed. because of the difference in climates(altitude, temperature, ect.) you cant just "set" it. Just test and tune. it only takes a couple minutes and remember. when you are adjusting the afpr make sure the vaccum hose isnt hooked up(learned that from brandonson)
justin , colleens was pluged in
i think the 02 pcms areok with the map , but for some reason the 03-05 dont like it
hers did run rich and it did run fine , but you could smell the cat was working overtime
just give the tech the part # for the reflash , they take that and call tech line , and they give the tech the VCI# , and the tech uses that when he requests the down load in their computer to load into the tech 2
yea i know...........it was easier to say both were unplugged. btw chads was freakin hot to re-plugin after the flash. small place plus hot enign = burnt fingers lol
sweet. thanks for the help guys. and the gateway laptop hinge
why reflash? get the hp tuners
LE61T PTE6262 Powered
Snowman wrote: remember. when you are adjusting the afpr make sure the vaccum hose isnt hooked up(learned that from brandonson)
WHOA WHOA WHOA....
I have a 2200.. turbo.... with larger injectors in ....am I supposed to set the AFPR with the vac line disconnected........ ??
if so.... that would be the reason I am running so rich..... haha
thanks
Lee
JDM Civic Hatch
just do what i did and have AAA tow it to the dealer
aigth well i got it done. dealer was way cool about it.
set the idle fuel pressure at about 42. nice and smooth.. runs pig rich at 12-14 psi. gotta get my wideband in. im temped to turn the boost up to about 15-16, but im gonna wait till the new engine is done just incase it blows. should have the new one in within 2-3 weeks.. i got stuck working the next 2 weekends.
so as soon as i get time, that bastard is going in.
thanks to all that helped me with the reflash. yall know who you are
cool let us know how it goes
and get a wide band o2 on it
ill let you knwo my afrs for comparisoon after friday........im goin to the track
bwahahahahaaha
what kinda boost snowman?
