Have a set of 32lbs injectors i want to try, they are bosh style, EV6 335cc/32lb injectors.
Anybody know a site with decent prices for injector clips
Thanks.
Nate
1995 Cavalier W/2k1 Engine
An even more in depth question. One site sells Connector Adapters for "
NipponDenso Male. Anybody have a clue if this fits are style of injector harness on 2k+s?
http://www.fiveomotorsport.com/Injector_CONNECT.asp
Nate
I know it might seem sketchy but have you thought about taking your injectors to a junkyard and just fitting them until you find a close one. but clips are cheap and this should only be a last resort
hey at least I got you a bump.
Kick azz is my boost hero!!!
k. Well, i found a good site and got some at 1/2 the price of what that site above was asking.
Now, i need to scanvange a 2k+ injector harness, or does anybody know if you can buy the FEMALE plug adopter for our Rochester injectors?
Nate
the 99-02 2.4 doesnt have a seperate injector harness , its part of the main harness
[quote=97cavie24ls(JDM&00s/c sedans™)]the 99-02 2.4 doesnt have a seperate injector harness , its part of the main harness
I know. But i just want to cut the injector section off
ah ok , at one point i was going to take the 96-98 injecto harness and mate it to the 99-02
but then bigger injectors became avaliable for us that used the same plugs
