I am taping my oil pan for my return line and I just wanted check to make sure im purchasing the right tap. I bought a 10 AN line male on both sides and I went to the hydraulic shop and he told me I needed a 7/8 14 ase thread tap I just wanted to make sure this is the right conversion thanks guys.
Kick azz is my boost hero!!!
I do hope you're welding that in and not just tapping and screwin it in...
I'm sorry I can't help you with your question we used a pipe fitting and therefore a pipe thread tap.
-Chris-
-Sweetness-
-Turbocharged-
I had my aluminum fitting welded into the pan after tapping it. Much better looking and performing, IMO. Find a machine shop that specializes in metal work, or a race fab shop.
Check out my Part Out List!! Great Prices !!
http://www.j-body.org/classifieds/detail/52925/
I dont see a problem with tapping into an oil pan without welding it, I have seen many like taht without leaking. A few I have seen, which I will probably do, after they threaded the fitting in, they JB welded around the outside of it.
isnt the hahn kit a tap and screw?
Yes it is but it is also pipe threads so they seal themselves.
5K PB: 24:50
10K PB: 54:26
Team Vision Racing (aka hypsy) wrote:Yes it is but it is also pipe threads so they seal themselves.
what do you mean they seal themsealvs?
Almost everyone uses pipe threads. I have a 5/8ths 90 degree elbow pipefitting with 1/2 inch line running from the turbo into the 5/8ths fitting.
