Can i pay someone to borrow one? i dont wanna pay 100 bucks for a tool im gonna use once. And i cant figure out how a PS pump pulley remover can do the trick.
tried that, they dont do the trick
well the gtp guys have clubs every where so my advice is to go
clubgp.com and see if someone in your area will let u borrow one
Check the cobalt and redline forums they pop up there quite often for 50-70 bux and you can always resell it back for the same amount. All youd loose would be shipping. I bought one new and sold it for 70 bux in 2 days... If you cant find one to borrow anyway. What size pulley did you decide to go with?
Check out my car....
http://members.cardomain.com/o4blackfire
What size did you choose Phlatcav?
PhlatCav, did you try a universal power steering pulley puller? It should have several different threaded inserts for various applications. I had tried just a regular one and found it didn't fit but the universal set did have the right one.
Unless of course your's isn't threaded.
the m62 pulley does not have a grove in it for a universal pulley puller
I went with a 3.0
What tool did you use to get it off then?
where did you get your pulley?
and if i had the puller you needed i would loan it to you in a heartbeat. sorry man
i have a puller but i live in BC.
