I am looking for a turbo manifold for my 99 Z24 2.4l. I need one with a T3 flange and internal waste gate.
im sure you could find one on ebay but your best bet would be a custom manifold like this...........
I looked on ebay but there is only one for the geekotec engines.
then your better off with the custom mani.....that way you can set the flange anyway you want to.....i bought my parts from JGS, but there site is down till june 5th...i had the T's and elbows welded and then i marked the flange and had that welded along with the wastegate flange.....i thought it was going to be a big pain but if wasnt that bad...
wow...totally forgot about jtuners.......duh.....
Does anyone know how good the jtuners manifold is. because by the time i get it shipped and everything its gonna be over around 500cdn depending on duties. but that is probably the way i will have to go.
It says that the mailing address must be in the same country. i need it to be shipped to canada.
M I N I O N - Sinbird wrote:go with HR..... awesome welds.
Time to change that Exploited in your sig to HRPro
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
dennis, sent you a pm
SpeedRacerZ wrote:M I N I O N - Sinbird wrote:go with HR..... awesome welds.
Your basically right.... We actually bought out exploited racings machinery and designs. Except that were a considerably larger company than they were. Our shop is 2-levels, 4000-sq feet on each level. and were considering making half of the upper area into 2 levels as well because the ceiling is so high!
www.hrprowelding.com
HRProWelding.com wrote:SpeedRacerZ wrote:M I N I O N - Sinbird wrote:go with HR..... awesome welds.
Wow I never realized your shop was so big. I do have one question for you though. I plan on purchasing a mani with external gate for my 2200 build. Do you guys offer any coatings on your manifolds or would I have to send it out on my own.
Thanks Jeff
hmm i wonder if freebs found a manifold too?....his crackkkeddd...make sure the mani has pressure cracks in the flange er else cracking might occur
<a href="www.daptronics.com">www.daptronics.com Huge Discounts on Electronics</a>
