What size are the Cobalt SS Supercharged Injectors? I'm piecing a kit together and am looking for injectors for an ecotec. Hoping to run between 225-250 hp. So will the SS Super injectors work for my application, if not which ones will?
370 cc. yes they will flow enough for 225hp
Thanx.
John H [Cavalierkid wrote:]370 cc. yes they will flow enough for 225hp
I was pretty sure the injectors were 310 cc ?
15.574 @ 89 mph stock without charger. new times with charger coming soon.
could these possibley work on a 2.4l????
If the injector harness is the same. Post 2k 2.4 and eco's have the same injector harness, I believe.
ive got them in my 2.4 , well the green tops from the 2.0 s/c
they plug in , but that is the easy part , the rest is hard
i had to have spacers made for the injectors and the rail so i could get them placed right
using the eco s/c kit injectors is alot better option
I've got my stock Cobalt SS\SC injectors for sale.
Modds:
GM Stage 2 with SFPHQ 2.8 pulley
Injen Intake
GM Dual Pass Aftercooler w15psi Surge Tank
GMPP Exhaust Manifold
CTi 3" Downpipe and Cat
Custom 3" Cat Back with Dynomax Super Turbo Muffler
ZZ Engine Mount
ZZ Front Trans Mount
B&M Shifter
NGK BKR7E Plugs
DC Strut Tower Brace
Soon to be installed:
2.6 pulley, Siemens 60lbs Injectors, NGK 2 Step Colder Plugs
Tune Time Custom Dyno Tune
