I am buying a used GM SC kit that is missing the map sensor. Does any 2 bar work? I am trying to find one for cheaper than GM charges. Also any advice on where to buy one would be greatly appreciated. Please dont waste your time or mine by telling me to search, I already did and wound up with more questions than before. Thanks in advance.
msd 2312 works i heard in a forum i read a few days back.. i already bought it so i hope the guy was right
40 bucks from summit racing...
if you got a 2.4 ive got 1 from the kit
pm me if your interested
purplezed informed me that devilsown sells one that might work. I have contacted them and they will let me know if they sell one that will work. Does anyone else know of any that will work?
I thought somebody sourced out a really cheap 2 bar map sensor from another GM car on this forum? Hmm... it was about 2-3 months ago... search back a bit I think you might find it... it was really reasonably priced.
-Chris-
-Sweetness-
-Turbocharged-
anything 0-5 volt 2 bar will work, make sure you get the clip for the wirring if it is different
Is there an easy way to know if the clip will be the same. I would be shocked if gm made this sensor only for this kit.
Here is a link to the company that sells it. I do not know if it is 0-5 volts or not though.
Timothy Pietraallo I had read that entire thread several times. I just never knew if it worked for you or not. Do you know if it even plugs right into your car without modifying the conector. Please keep us posted. Thanks Wade
Well I searched on google and it does show that it is a 2-bar on websites. Your best bet would be to call the dealer and ask them directly if that part number is a 2 bar just to double check. I think it is for Grand National and GM changes there part numbers from time to time as well. But the guy from the dealer said it was a 2 bar.
If you search google and type in: GM part number 12569241 and scroll down and just read some of the briefs on the wepage it says its a 2-bar. Here is what the box says:
0211M3 LC21 GR.3.682 (on the top in smaller font)
ACD#213-1520
GM#12569241
Then then numbers on the senor itself:
110603 1750
PART 12569241
LOT G1LKF3
(then a barcode)
On the back is just says 466 and C B A under the plug area
The real ? is will it plug in or not. That is what I need to know. Have you plugged it in or could you real quick or post a pic of the end? Thanks Wade
before someone hurts themselves trying to think too hard, I'll post a pic of the one that comes with the GM kit... this is the 2.0.
and for f#$k sakes the injectors too you can buy them at www.injectors4u.com ==> injector pricing ==> ctrl+f ==> 24.99 each and they ship within a day.
ge_forcez22 wrote:before someone hurts themselves trying to think too hard, I'll post a pic of the one that comes with the GM kit... this is the 2.0.
dont you mean
2.4 not 2.0 ????
and from what ive heard those injectors are not new , but reconditioned used injectors
dont you mean 2.4 not 2.0 ????
...nope 2.0 bar, not 2.4 bar, I assume you thought I meant 2.0 eco, I should have been more clear
Fuel Injectors: Reconditioned Fuel Injectors at Injectors 4 u.com
We sell reconditioned fuel injectors direct to the installer, automotive shops and service centers.
you heard right, or did you go to the site, lol
when you put 2.0 , i was thinking you meant the 1 from the 2 litler motor , and not the BAR rating
lol
i went to the sight , but never read the site , just looked at prices
it wasnt tell later that i heard they were reconditioned
Does the sensor in the kit have a three hole setup to connect it too? Mine is not shaped like that its shaped like a regular map sensor. I will post some pictures when I get home.
Timothy Take a look at the one in the link to the ebay auction above. If yours has three round holes it will not work unless you have the conector that plugs into it and then splice the wires on your cars conector to the old three hole style conector. Can anyone post a pic of what the ion redlines map sensor looks like.
the redlines map isnt a map , its a TMAP
if you search through the eco sc reflash post there is a pic of it , it is a 4 wire sensor , also it is not a 2 bar map , it is over 2 bar , how much over im not sure
That is how mine lookes. Only thing is I can' t tell in the picture or not but mine needs a cut out for the center opening as well as the one on the right side. So I would need to buy one of the hookups to this sensor to splice into my factory one?
Ya the one I have is this style
http://www.raceprovenmotors.com/ebay/3bar1.JPG . This is a 3 bar thought but mine is the style of this one. Will this plug into the cavaliers systems or do I need to purchase a connector?
