Why are you gonna be a bitch?? You obviouslly ain't winning no shows so dent that firewall in, like I did. lol
Bad ass Turbo man, I have had mine on since Easter since I told you about bad ass deal I got with the local shop here, and ran it at 20+ psi since and without air filter, not a hair of shaft play, my 57 trim took a crap after 10 dyno passes at 15+ psi, but it was also a Garrett small shaft and 2+ years old.
Did you get a warranty with it??
Also tell me how that divided housing works out for you, heard some good stuff about it, but I forgot what I heard about it.
And I also wanted a V band you basterd and the only way was with the T4 housing so I said screw that I didn't feel like changing the damn manni.
P.S you will love the sound the Turbo makes even at 0 psi it sounds like a semi truck, never heard any shaft Turbos sound like that. Only balls and dual balls.
Good luck spooling the is it 68 or 82 A/R, they are pretty good about spooling but laggy till about 10-12 psi.
I had my boost controler up all the way the other day to see if the Turbo will make over 25 psi, it was slow till about 10-12 and then it spooled up to 30 psi in a fraction of a second. By the time I let off gas pedal I was at 30. lol Ups.
Good luck with that monster.
I used a dead blow on the fire wall it works quiet nice in the case you go that way, so you can run a 4-5 inch filter on it.
11 second daily driver!!!!
Race Related 727-561-9440
13's
----12's
----11's
----10's
Its a t61. No warrenty, but it's been used for a total of like 10 minuytes before a sohc honda owner realized he could only spool 2psi with it. Its a t4 exhaust housing yes, with a .84 a/r. I know thats gonna be too big for me so I just ordered up a .68 a/r exhaust housing. Should spool by 3800-4000 with the cams and ported head. Thats what I am hoping for at least. I can always raise the rev limit a little bit to make up for the added spool time.
holy @!#$, thats a mother of a turbo.
anyone else running something that big on their LD9's? When did they see boost?
looks great, though.
Me... fitment can be a bit of a chore... everybody knows my spoolup and boost threshold points I think.
Mind you mine's not a full T04.
-Chris-
-Sweetness-
-Turbocharged-
