Ok you are somewhat on the right track and it would help you saying that you are working with LD9.
If I am correct you are running high impedance injectors so Ford brown tops are out of question, you will need some kinda of high injector. If I am wrong disregard I haven't messed with a LD9 in almost 2 years or so, but still remember a lot.
You are deff gonna need a fuel pump do it right, so you don't have to worry since you are gonna be putting extra stress on it raising the fuel pressure.
As for what Higgins said about the FPR it would be nice, and the fuel gauge to be able to mess with the fuel.
Also, since LD9 doesn't have a shrader valve you are gonna need to drill the fuel rail and tap it to get the gauge on it.
So get some 310 cc injectors for now, like GM out of a GM supercharged set up, bigger pump, and FPR, I think it should do you a lot of good.
MSD if that is what you are reffering to, you will not need and it is strictly optional for the amount of boost you are running, stock system will not be bothered with 6 psi of positive pressure just get some colder plugs like some NGK's TR6 and gap tham down to (I prefer .029-.030) for your boost level, but that is STRICTLY MY preference you can do whatever YOU want.
If you can tell me if you are high or low impedance I might be able to get you some injectors.If you would like.
Take it from me you wanna run bigger ones. It is your choice however, many have been known to run those boost levels at stock injectors, will you??
As for FPR, you can get Accel, that bolts on straight on your rail, and you hook up vaccum to it and via gauge set it to what you want. Or you can get any FPR but more modifications to your rail might be needed.
I might have something for you(maybe a complete rail drilled with FPR on it, maybe) shoot me a mail.
Again, this is only if you choose to do this.
FMU depends what ratio you are gonna run on what size injectors you are gonna use.
Most people just shove the biggest disk such as 12:1 in the FMU.
So lets do the math, say you are running 45 psi of fuel at idle and 55 on Wide Open Throttle usually reffered to as WOT,
12:1 means that for every pound of positive pressure you increase fuel by 12psi!!!!!, which at 6 psi should be EXTRA, 72 psi of fuel pressure on the top of that 55 which theoretically should put you at 127psi of fuel pressure.
However most of the stock pumps crap out of even some bigger ones at about 80 psi or so, even tho some high pressure ones go up as high as 100.
So the only thing that running such a big disk in the FMU will make you do is choke before you go in boost because for the 1st 2 psi it will max out your pump and since you will be so rich at 80 psi of fuel pressure it will take care of other 4 psi.
That is why I say chose disk based on injecotrs.
I have ran as low as 1;1, which you can get by completely removing the disk out of the FMU since it has boost refference it will only raise it 1;1, but unless you are running 500+cc injecotrs I DO NOT recomend you do this.
You will not ride around with lap top in your car unless you choose to, because engines don't just lean themselves out because they want to, you usually have to lean them out yourself.
Once you set everything on the dyno you will not need to touch it anymore for the most part unless you are raising the boost, but it gets very addictive.
I ran 5-6 psi once and when I felt how good it feels, day dreamed about my boost gaige ever hitting 20 psi mark, and now it is over that many thousands of dollars later.
You will NOT need to upgrade MAP unless you are running GM reflash, your ECU will NOT understand bigger Bar MAP sensor if you just one day changed it without reflash.
1 Bar is reffered to what we have it is all vacuum up to 0 psi or in/Hg.
2 Bar is up to 14.5-14.7 psi
3 Bar is up to 29-29.4psi
4 Bar is up to 43.5-44 psi
5 Bar is up to 58-58.5 psi, roughly, but again your ECU needs to understand these to be able to do anything with them.
Only thing you might have to do if you are NOT gonna reflash is you might have to run a chack valve between your MAP sensor and manifold since it is set for all vacuum, and once it sees positive pressure it might freak out a little.
So if you have any other questions just ask, I do however have some parts that could greatly benefit you if you want PM. me or catch me on AIM S u nCavi98.
Good luck man.
11 second daily driver!!!!
Race Related 727-561-9440
13's
----12's
----11's
----10's
