i was wondering if GM Performances high performance cams would work fine with the 2.2L Eco S/C kit , i have acgtually had a few people ask me and question whether it would run right.
the specs are:
Duration @ .050 - Intake 268, Exhauset 268
Lift - Intake .464", Exhaust .464"
it also says: This performance camshaft set will increase horsepower in both naturally aspirated and turbocharged engines.
so im just wondering about with a supercharger
it should work fine.............would you mind posting the part numbers for the cams
yea sure, sorry about that, the part # for the cams is
88958648 - Ecotec Camshaft Performance Set
(off topic- ur cav looks pretty sweet, normally i hate that evo hood on anything but a evo, but somehow it dont bug me on ur cav).
cams- i dont see why they wouldnt work.
could always try calling gm.... not your local dealer, as i'm sure they probably wouldn't know, but the performance parts tech line, if there is one.
Arrival Blue 04 LS Sport
Eco
Turbo
Megasquirt
'Nuff said
for the price i would get the comp cams.....they have 5 different grinds.
cause you are lookin @ 700 from gm and employee price is about 600
where as the comp cams are 550
ic, yea i was thinkin about the comp cams, im gonna have to get adjustable cam gears and their like 380 from GM, so ill prolly go with the comp cams.
Jake- thanx for the comment on my car, im glad someone likes it. Im trying to make it as clean as possible and not be a botched up and s#%t. im thinkin about a bodykit, but im not sure whether i should get Wings West Bigmouth, or Avenger or the Type J, or just keep the stock kit on it, im not sure tho, but thanx for the comment
keep the stock kit and play with the motor more.
The GM performance cam is a blank cam you have to take them to a machine shop and have them cut to your specs. so yes they will work perfect for any application as long as you cut them the way you want them to perform.
RICE DONT MEAN YOUR SLOW
not the ones he posted a part number of............they are actual cams.
they have blanks for leik 90 a piece.........
or the set for 700.......ready to drop in(so to speak)
GM told me the grind will work with both N/A and Forced induction cars, so yes they will work. But if your going forced induction I would recommend comp cams for the ideal gring specific to your needs.
OOPS Ideal grind is what I meant, long day already!
I don't think the GM performance cams will work with the stock ECU...reflash or not...not 100% though...unless you have some sort of engine management
_
2002 LS Sport coupe
