Ok well for the boosted guys who have built up their engines... did you get a only block and get it machined and then build it up and then do the swap?
Because what i am looking for is a LD9 block and i am going to start building it all up as i have finally decided this car is getting built to the MAX! as i am pushing it almost to its limits now with the turbo and supercharger on their with about 12-13psi into the engine..like i am going for 22-25psi into the engine and just going basically full out on this car... to see if i can hit over 450hp on a street driven jbody... so let me know if you have one or know where i can get one.. i just need the block.. nothing else... and preferably one that wasn't blown or any thing... burning oil is fine though...
The First Twin Charged jbody
i thought you were getting an engine built by Jbody performance?
Yes, I have purchased a block on ebay....then do the swap.
I'd just get a complete motor if I were you.
Josh, I have a 96 block at my house, I live in WI, USA tho. I'll hit u up on MSN sometime. You would have to do something with the knock sensor. You can drill out the threads and tap it for the 99+ knock sensor no problem, if I am thinking right, I always forget what year range the sensor was larger on.
CCasper wrote:i thought you were getting an engine built by Jbody performance?
was going to but this way its cheaper and faster when it comes time to do the actuall swap....plus im going to get every thing paited up nicly and such..
Fst Cavy - i dont know if i want to be drilling into it.. i think i would rather every thing just be there....
I bought a complete engine from the yard, tore it down, collected ALL forged internals and valvetrain, now im dropping the motor off Monday to the machine shop..
Since you dont need a complete engine, hit up the yards for some blocks.. Have fun stipping it though.
I have a stripped block and crank sitting around. $50 and shipping, E-mail if you want it.
Cardomain|
Myspace
thanks minion ill send you a pm....
