Well I tapped into the oil pan a few weeks ago and the hole is below the oil line in the oil pan. I was wondering if I would be able to use a fuel pump that I have laying around and put it in the return line to help the returning oil from the turbo.
<img src="http://ad.nicoclub.com/banners/nico-banner1.gif" ></a>
id just block that hole off and tap into the dipstick tube. i think someone even sells a kit for just that.....
Roscoe wrote:id just block that hole off and tap into the dipstick tube. i think someone even sells a kit for just that.....
www.jtuners.com
They sell a new dipstick for just that purpose. I think it's like $70.
I also would recommend either taping the oil fill tube, or going higher. doing a pump is just going to be asking for trouble. if that oil line can't drain fast enough, it will back up to the turbo, and if the turbine housing can't drain, it's going to strain the oil seals, and blow those, then you'll be burning oil like crazy as it goes into the exhaust and intake pipes.
dipstick tube make life easy on yourselfe
