I have a 1st gen talon b.o.v
I was wondering where to run the vacuum line to.
I know it should go to the throttle body, but can i run it to the intake manifold???
Thanks
Gary
Try searching. It's your best friend and it has the answer.
5K PB: 24:50
10K PB: 54:26
Yeah i have searched the net...but i cant get any vacuum diagrams.
It aint hard , i just wanna be positive that im doing it right.
Just put it anywhere after the throttle body plate. i.e. drill, and then tap the hole. or the easy way would be to tap an already existing vaccume line, if u can't find those, then search. They are small plastic, sometimes rubber lines from the throttle body.
Thanks
I wasnt sure if it would receive adequate vacuum if i tapped into another vacuum line.
Did you try searching this site instead of the whole internet? There's a diagram, crude as it is, that Shifted made and I know for a fact that it's in the search listings because he posted it last week! Among other times in the recent past.
5K PB: 24:50
10K PB: 54:26
thanks
i searched vacuum.......and it pulled some stuff up
before i search vacuum diagrams...and nothing pulled up.
