can you use the browns on a 2000 + 2.4L?
Friends Don't Let Friends Drive Stock!!!!!
That is a 2.3 turbo right? So would those also be in a T-bird turbocoupe?
what would be a good injector and what car for 2000 plus...im looking for a rate around there i looked at teh green tops that are 42lb and those might be alittle big....but im not completey sure......and the 32lb reds seems too small...anyone know a decent size to be run with the GM reflash and 10 lbs boost off a T3???
Thanx Charles
the part number for the brown tops are E7SZ-9F593-A and the short # is CM4637
Click the banner to enter the best Quad4 & Twin Cam site on the internet.
Reds are 30lbs
There are 32 and 36lb high imp solutions out there.
Try five0motorsport.com, can't say anything too great for them expect they have both of the above injectors. No compliants though.
BTW I have a set a 32lb high imp injectors in the classifieds.
Save a Tranny, Roll-on
15.3@88m.p.h.(I/E)
15.2@94m.p.h.(S/C'd)
15.5@89m.p.h.(Stock GTP)
BLWN Z24 wrote:Reds are 30lbs
Just read your classided about the injectors. How well did they work for you? did you have a wideband to see if it helped? aslo what is this " HPT software"?
Thanks
I just bought 32s so trying to figure out it they'll work well or not from ur experience.
Nate
1995 Cavalier W/2k1 Engine
My 32's worked/ are working awesome.
Car throws flames now so I'd guess it is a little on the rich side.
Better safe than sorry
Unfortunately I have no Wideband so as far as any actual measure of A/F, I have no idea.
HPT is tuning software released by HP Tuners for our vehciles
(check out the sticky in the "performance" section)
15.3@88m.p.h.(I/E)
BLWN Z24 wrote:My 32's worked/ are working awesome.
Thanks. What size injectors are u using now then?
Nate
they are only 37lbs at there rated psi which is around 38psi i beleave so on our cars its at 43psi so they would be more the 37lbs
just a heads up
So the Brown tops work on the Ecotec too right? I think I read that somewhere.
this is the last part I need for boost lol
Forgot to add: Is it from the 2.3 turbo engine? I know someone asked above w/ no answer. And the ECO is high impedence? sorry for the dumb questions I know
Ok cool thanks shifted looks like I have more searching to do haha. man as much as you answer peoples questions, you should be geting paid for this!
Yes, they are the injectors from the 2.3 Ford Turbo Coupe, yes Eco is high impedance. If you're a little more brave, depending on how you are tuning them, you could try to run the 440's (Green Tops) from an SVT mustang I believe, or if you are running low boost you can run the 320's (Red Tops), both are high impedance. I'm running the 440's as I stated above.
I sure wish I could get paid for this
I'd be rich, lol
oh ok I was getting the brown tops confused w/ the red tops, I will use the red tops then.
I will be on 7 psi from a .42 .48
What car are the red tops in? Sorry to whore up this post or if I am thread jacking, I dont post much lol I just read things on here! This is really helping me out though!
Much appreciated Shifted!!! And sorry if i jacked your thread Chris Fontana.
I love this place
