I was just wondering if any one could come up with a basic list of mods to run 20lbs of boost on a 2200. i kno boost is just a relative term. so relatively what would i need.
Forged pistons, forged rods, heavy duty piston rings, all new bearings, ARP headstuds, Cometic headgasket, fuel pump, injectors, and t uning.
275hp & 306tq - 1999 2.2 ohv
13.2 @ 108 mph
^^^These guys would know, especially Adler.
I would also like to suggest an early 2.2L (90-93) oil pump. It will give a little more volume, and should be added to any 2.2L/2200 build.
Tuning will be the key though. Nobody has proven that it is not possible to run 20 lbs on stock internals, so you never know, with the correct tuning...
fortune cookie say:
well im already pushin 15lbs on a 60trim 42/48 turbo on stock internals, i dont think i want to push much more.
Don't be scared. 2.2s are only about $400 from a junkyard.
13.2 @ 108 mph
the one thing im worried about is valve float. is the stock valvetrain capable of handleing that much boost. of course i would put at least a new oem valve train in if it could handle it.
I ran 20-22ish psi on my 2200 with the stock valve springs that had around 90,000 miles on them. If there was valve float, I didnt notice it while driving and it didnt show up on the dyno.
If I had to do it all over again, I would have bought some stiffer valve springs just incase.
13.2 @ 108 mph
do u think a new oem valve train would b ok for 20psi. my goal for the engine is 20psi.
what would the best piston rings b to use.
The stock springs would probably be fine seeing how I didnt notice any problems.. But after I tore down that engine, I was told that it would have been a good idea if I had used stiffer valve springs when running that much boost.
13.2 @ 108 mph
Looking at the numbers, the OEM springs should not be able to handle 20+psi at higher rpm, but if Adler has done it, then you can't argue lol.
Adler, $400? You're getting ripped off,
fortune cookie say:
yea u are i can get one around here for 150 then give them a core engine and get 50 bucks back
I used Total Seal TS1 gapless rings in my 2200. I personally know of 3 people who have used Total Seal gapless rings in their turbo 2.4s and a turbo 3.1 V6 without any problems..
OHV notec wrote:Looking at the numbers, the OEM springs should not be able to handle 20+psi at higher rpm, but if Adler has done it, then you can't argue lol.
$400, ripped off? I am confused, what are you talking about?
13.2 @ 108 mph
Oh, nevermind.... I see.
I never had to buy a 2200 from a junkyard. Whenever I blow motors, I either just slap a new piston in there, or I always have a back up engine laying around.
13.2 @ 108 mph
Adler, i didn't see a size for my engine, 3.540, but i see they do custom stuff. Is that the way you went? And if you don't mind, how much would a 4 piston set cost?
when you all say higher RPM are we talking higher then stock?
stevefire wrote:when you all say higher RPM are we talking higher then stock?
I wasn't.
fortune cookie say:
VTLoki wrote:Adler, i didn't see a size for my engine, 3.540, but i see they do custom stuff. Is that the way you went? And if you don't mind, how much would a 4 piston set cost?
Are you talking about Venolia? If so, yes they do custom stuff. My set of pistons were a "custom" set. My set cost $350 ish over two years ago.
13.2 @ 108 mph
Actually, i was refering to the gapless rings. sorry, i should have been more clear. But wow, only $350 for a set of pistons. that's a good price.
And in your opinion should I go with the gapless rings or a set of the wiseco XX rings? which I already have in my posesion.
Here is a link to some info on the wiseco XX ones. pdf file:
link
But i was reading about the gapless ones, and if i'm going to be running high amounts of boost, the gapless ones sound like they would be better....Any one have experience using either?
I never noticed any problems with my gapless rings. Mike Karas (turbo 2.4), Curtis Walker (3.1 liter V6), and Aasyranth (turbo 2.4) all used the Total Seal gapless rings without any problems.
I dont have any experience with the Wiseco rings.
13.2 @ 108 mph
were can i get the gapless rings for a standard bore piston for my 2200. ill building my engine soon.
http://www.totalseal.com/
13.2 @ 108 mph
I went there and couldnt find the linkto actually order them
It would be better for you to call them.
13.2 @ 108 mph
