Hi Guys
I just want to know if its even possble to make your own boost controller like making some kind of software and then make a lcd screen that you can select the type of boost you want like if you want to run stock driving like the daily driving or a other option of setting at drag setting is this even possble to do?
Opening Soon Kustom J's
if you were a computer programmer and could build the entire system...im sure it could be done.
5K PB: 24:50
10K PB: 54:26
you can easily make your own manual boost controller. just spend about $10 for the hardware at home depot or lowes and it could be done. it will be a bleed type i saw a website on it before. looks fairly simple
where is the how to on this at for the manual boost controller?
are you sure you know enough about boost to be playing with boost unsafe custom boost controolers? the reason I ask is because Its fairly obvius how it works.if the wastegate sees boost and regulates how much accordingly. then by just getting a bleed valve inbetween the gate and source and bleeding off boost you let the wastegate see less boost hence more in the egnine. I know this sounds complicated but its not. if you cant figure this out for yoursefl stay away from it. turbos and engies are worth more than a cheap thrill.
Kick azz is my boost hero!!!
well can i ask a simple question instead of getting my head cut off
Thats a good find. The one i remember reading about is similar. But to be safe you should put a thin lock nut in between so it doesnt come apart.
Considering that a boost controller can break in ways that can cause catastrophic engine failure, you should be vary careful about which one you choose. I've seen home made ones that worked fine, but if you don't take ecery precaution, like using locktite and/or thread sealant where needed, you can get into big trouble. Manual boost controllers are cheap. And you can get a Greddy Profec B on ebay for $200... all in all, they aren't expensive enough to really be worth fiddling around with sketchy homemade stuff. You'll be much happier in the long run if you spend some more money now, and don't have to spend A LOT more down the road.
Arrival Blue 04 LS Sport
Eco
Turbo
Megasquirt
'Nuff said
Kustom 96 Sunfire GT wrote:well can i ask a simple question instead of getting my head cut off
doood sersoiusly fcuk you then. Go to another website and let them show you how to @!#$ up your car. I was just trying to help you.
put it this way would you rather have some one tell you whats safe or would you rather just get the info and screw up a ton of money?
sometimes tuff love is all that works. what do you want me to say jeez
Kustom,
I've seen it done before. I still wouldn't do it though. Just buy a used one. I'm sure you could find a turbo xs one for like $70 somewhere, if not a think you could still get a brand new one for like $85.
