its all the same wheter its for the j or n body
It's not ALL the same, but most of it is. There's a cruise control cable in the kit that's N-Body specific. Other than that though, I can't remember what differences there were.
I don't think there are any n-body specific brackets at all.
it's all good, I was just hoping to make back some of the money by selling any extra parts to someone here that may have bought a bare unit off ebay or something,
'00 Grand Am 2.4L LD9
http://www.cardomain.com/ride/816505
i removed my cruise controle when i did my 5 speed swap so i never ended up using my cruise bracket
i used the cruise bracket as well as the cruise cable when i installed the charger in my cav.
purplezed wrote:i used the cruise bracket as well as the cruise cable when i installed the charger in my cav.
You're supposed to use the cruise bracket but not the cable that comes in the kit. You use your stock cruise cable and just route it differently.
im using the cable that came in the kit also
it was a little longer than my stock 1 , and reached better
Interesting. I didn't even check to see if the connectors on it were the same.
Mine's in my basement somewhere.
connectors are same. reason i ran it was with the TB being farther over, the throttle cable routed differenty and the new cruise cable being longer, routed right beside it for a nice matched pair of cables!! looked much better then stretching the cruise cable over to the TB.
here is a picture of mine using the cable from the kit , its a little big
thank you jake , lol
i got the bracket and cable from jake
i added the paint to it though
