okay, well i have pretty much decided on turboing my car but the guys at the shop i work at are all screaming to just buy a V8 or some new car already fast. that just makes me want to turbo my 2.2 ohv all the more. either way here are some things i know and some questions i have.
for the fuel injector i will be adding an extra one in the intake piping.
will the turbo exhaust manifold from a 2200 bolt up to a '96 2.2?
they also said that i will burn through cat converters so fast it won't even be funny. is this true?
one more thing that i have a ? on right now. Will the ECU or whatever it is called (i work for toyota) go nuts from the extra fuel injectors and the boost and will it throw all kinds of codes? if it does is there a way around this.
I want this car to be my daily driver. The one tech said that if i can turbo my car and get it to run properly then i will get a TON of respect from him and that i will be a better mechanic then he is.
oh and one more question about tuning. after everything is installed and i have the piggy back system installed and stuff i just tune it to get the A/F meter to read about 13.1:1 or close to it basically right? or is there alot more to tuning than getting the A/F meter to read right?
http://www.helpelijah.com
I think 13:1 air/ fuel is a bit lean... Most people suggest around 12:1..
you want to tune it to where you make the best power on a dyno. it could be 14.7:1, 13.5:1 or 11:1.
welll ^ wouldnt u make the most power at a leaner # because it is making a bigger boom......i thought you would want low 12/s across the board thats what i have gathered up form this site.........i d k tho.......better safe then srry....
Thanx Charles
Poundin fire that is the dumbest post ever!!! And this one a close second.
Todd wrote:Poundin fire that is the dumbest post ever!!! And this one a close second.
Why is it dumb? Do you know what tuning is?
Max power is made at the edge of lean. You can lean out the car until you get knock, wherever that is. People say 12:1 because nobody gets knock that rich, but if you put it on a dyno, and we had a way to accurately tune the fuel curve, I can bet there is power to be had by leaning it out. How far you go depends on how far you can push it until you see knock.
Thanks Shifted. I guess that reply from Todd show how few people know how to really tune. I am by no means an expert in any way, shape or form; but I see too many people thinking that a given AFR is right or that all you need is a XX:1 AFPR. Probably freak people out to find out what I have tuned my cruizing and light throttle AFR to be.....
yeah i figured as much. but i don't have ready access to a dyno so to tune it as a daily driver until i could get to a dyno is what i was wondering about. thanks for the answers on that.
i also have the other three questions:
1. will the turbo exhaust manifold from a 2200 bolt up to a '96 2.2?
2. they also said that i will burn through cat converters so fast it won't even be funny. is this true?
3. one more thing that i have a ? on right now. Will the ECU or whatever it is called (i work for toyota) go nuts from the extra fuel injectors and the boost and will it throw all kinds of codes? if it does is there a way around this.
one thing they are also getting on my case about is saying that i would should be a certified master techian to even attempt to do this myself. i say screw that.
1: I'm pretty sure they do. from what i can tell, they have the exact same manifold from the factory
2: someone that cares about their cat would have to tell you about this. I had mine removed years ago.
3: if you go too rich or lead (from the computers program) it will throw a code for just that. then after about 5 min of driving within proper parameters, the mil light will go out.
thank you for the other answers. either way as for the cat i don't see why it would burn through them i mean like all the stock turbo cars come with cats... blah, blah, blah.
so i just want to be sure i can put this turbo stuff on my car and not throw codes. (after tuning and the such).
i have a new question:
Will i need to get a new wideband O2 sensor? from what i understand i get the apexi safc-2 to adjust the fuel system and just connect up the A/F sensor to the stock sensor to get the readings.
wideband is a great idea. it lets you know what your afr is at all times, in real time. great tool everyone should have one.
2200 manifold from ebay
get at least a high flow cat
and tuning is hard, crappy work, but if you manage to get YOUR cars optimal afr then your car will make the most power it ca, shifted is right............ the brink of lean will net you the most power, but most people will run richer because of less chance in detonation, which is always a good thing for your grocery getter...... it is for me ....
and It actually happened to me,
maybe someone can correct me, my CEL came on the other day after a HARD rip from a dead stop, too rich..... apparently the CEL for too rich sensor 1 only comes on when your in the high 11's AFR, that is TRUELY too rich........ for a stock motor
the AFR will determine the HEAT inside your combustion chamber, 12.1:1 - 12.5:1 is the best for a stock motor, 13.0:1 for a built motor because they can expell heat better.
Lee
JDM Civic Hatch
I would definitely recommend using a wideband O2, and if you can get one with datalogging capabilities, you'll be even better off. Since you don't have a dyno readily available, having a datalogger and the requisite computer software will allow you to see what's going on inside the engine with a laptop. I'd recommend using a Greddy eManage over an APEX'i SAFC. The eManage has more flexibility and allows more control, and again, laptop tuning.
Opfer benotigt. Keine Erfahrung notwendig.
Victims needed. No experience necessary.
okay here is a new question. i was looking at the MegaSquirt system.
does that take the place of Apexi - Safc2 and the MDS-BTM or whatever it is?
if so i think i will deffinately go with that.
well i did my own research and found out that with MS that i wouldn't need a MSD or Apexi anything that it is self contained.
now for a new ?
will using the MS cause a CEL to go off or does it take care of that too?
The Mega Squirt, from my understanding, replaces the stock ECU entirely. I'm running an AEM EMS on my Laser, which is a full stand alone system, and I'm assuming the MS operates the same way. The stock ECU has its own set of parameters, specifically for the engine. When something steps outside those parameters, the ECU sends a code and lights up the CEL, alerting you of an issue. But stand alone systems require the user to input the operating parameters, and then monitors those parameters. It won't solve the CEL issue, because it won't drive the stock monitoring system. All engine monitoring will be done with the engine management system. I'd recommend investing in guages to monitor vitals like A/F, oil pressure and temp, fuel pressure, EGT, all of that so you know when something is wrong.
that is exactly what i thought. i just needed a confirmation. i can't wait to get started on this. i think the megaview for it will display alot of the that info if i am not mistaken.
I haven't done a lot of research on the Mega Squirt system, but it's been my understanding that it's a DIY kind of thing, more of a kit that you assemble. I don't know if they have a fully assembled system that's ready to install or not. If you haven't already, you should check into that before you buy.
