will this reflash and map sensor allow my ecu to adjust fuel per pound of boost? or is thisonly adding a set amount of fuel for the boost limitations of the kit as a whole?
thanks...
and if I choose to get this can I just walk into a dealer and have them reflash and can I purchase the map sensor?
LE61T PTE6262 Powered
the map sensor will need to be modified to work
the wiring is different
the 2.4 guys have had decent luck with the s/c program and use of a turbo
You need the map sensor and i think iat sensor from the charger kit. Also there is few other small things.
"Growing old is mandatory. Growing up? Definitely optional."
QBE (73H 800573D 0N3) wrote:will this reflash and map sensor allow my ecu to adjust fuel per pound of boost? or is thisonly adding a set amount of fuel for the boost limitations of the kit as a whole?
thanks...
It will adjust fuel
and ignition timing based on manifold pressure from vacuum to 14.7 psi.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
actuallly i think the map for the s/c is a 3 bar , not a 2 bar
i know the cobalt's and ion's have been running 18psi and it reads that on the factory gauge , which gets its siginal from that map sensor
nice.. well lemme know what I need...
connector to map sensor.........cause its a 4 wire and you have a 3 wire., You also need to find a way to attach the sensor. as on the supercharged manifold it doesnt have a vacuum nub so you need to make an adapter. i was @ 97cavie24ls(JDM&00s/c sedans™) house lookin @ the one he has and it wont plug in like ours do. there is a hole in the manifold the senosr has to sit in and the sensor has an o-ring on the sensor.
so to make it wourk you would need to get an adatper you would have to make.
get a square drill a hold all the way threw. put the map sonsor on one end and then tap the other for a vacuum fitting and then you can run a vaccum line to it. but im not sure exactly how well it will work.
So thats my theory!
Dont know how well it would work or how accurate.
it looks like like its a temp sensor too
no more MS phil
also wont this limti you to a certain amount of injectors?
Kick azz is my boost hero!!!
Listening as well...
im ready for this now id ditch the fmu in a heartbeat and love to not worry about tuning. My injectors will be a bit larger but hopefully this will be a common swap soon.
*2012 mazdaspeed3*
