Anyone know where I can get a 90 degree elbow that will actually fit an 02 ecotec without rubbing the hood and has a 2.5 inch pipe opening
i had problems finding one so thats why i made this. I might sell it before long after i finish my intake manifold
If your interested in custom aluminum tilt wheel levers hit me up!
wow, that is a really good idea!
Weapon R sells just the Throttle bodie elbow for there cold air intakes that has a 3 inch opening on each side...its really low profile and clears the hood nicely and looks good too. Theres a post floating around here with pictures.
Doesnt the rsm kit have an elbow?
he said
02 Ecotec.
The 03+ have much more hood clearance and the weapon r elbow will not fit.
Rodimus - The weapon R will NOT fit the 02 ecotec, so dont buy it
I found a "cobra" elbow on ebay for my turbo kit that worked great! I cant remember what it cost though.
I'll see if I can find it again.
I have a few pictures of it in my
AZJBO Garage. Go check them out to see if it is what you could use. Send me an email if you want me to find you one.
"Growing old is mandatory. Growing up? Definitely optional."
Yea I know the Weapon R wont work QBE has it on his car and it scrapes, I do have the RSM kit which was designed for an 03 so the coupler they gave me didnt work at all, so I have an elbow from a 2.4 kit, if you have seen the kit its two 90 degree elbows and a straight pipe so I wouldnt be able to use anything else that relocates the TB or anything like that
ATP Turbo I think has that cobra head one but I wasnt sure if it was any better that the Weapon R.
it does fit.
It is VERY close to the hood though. But its rubber to if it did touch for some reason you wont have problems.
I dont think it will go over the throttle cable bracket though.
I think a TB relocation pipe would work for you. You might need a different pipe to connect to the s/c, but im not sure.
possibly you could need a shorter "relocation pipe"
