I am working on adams (njhk) car and they are falling maybe 1/4 inch short if anyone has them in an 03+ ecotec rail what did you need to make them to fit??
thanks
LE61T PTE6262 Powered
You'll probably need to get the larger round spacers I "Think" they come off the 2.0 motors but I could be wrong, I used 36lbs GTP injectors and they were a butt hair shorter but sealed no problem.
I was under the Impression that the green tops were supposed to be direct swaps, Are you sure they are the proper green tops?
Eric might be able to tell you more, hes actually got a set fo the spacers.
208whp 239wtq
13.7 @ 102mph 2.19 60'
NotsoOceansideEco wrote:You'll probably need to get the larger round spacers I "Think" they come off the 2.0 motors but I could be wrong, I used 36lbs GTP injectors and they were a butt hair shorter but sealed no problem.
yeah these only need maybe an 1/8th of an inch or so... thanks for the help...
we did it... now we need to figure which wire for the clips is pink and which is black.. then we need to hope its going to idle LOL
fairly certain pink is the constant 12v supply, lookin at the stock injector plugs should make it fairly easy to tell
208whp 239wtq
it doesnt matter which way the wires go , it will work either way
the spacers are in the 2.0 s/c motor , and in the 03-05 2.2 heads
I told you guys how to make them fit. LOL.
Ron...they called you too? LOL
5K PB: 24:50
10K PB: 54:26
nah we got em to fit and run it's all good...
