No those are not them
But they are 310cc high impedance so I think they could work with the s/c reflash ???
Is that right?
Yea if they are 310cc high impedance I dont see why they wouldnt work.....only thing u might have to do is get new clips......but thats if they arent a direct plug in.....
Did you email the guy askin if they were high impedance? I would check that first before buying them...
id have to say those a LOW OHM injectors , since he lists then as older injectors , and most people would list them as HIGH if they were
and those have the older plug on them , so you would have to cut and add new connectors
i think id pass on those , unless some one knows for sure they are HIGH ohm
So what I understand here is that i'll be better with red top injectors.
Will the red top fit my actual injectors clips?
Ok so wich injectors will fit directly to it?
Is it hard to change connectors?
I put red tops in my car.......... 2200 2001...........
but my good friend got me a new harness.... we only had to splice 2 wires.............. and the new clips went on ........ I think we used a z24 injector harness and clips................. took 10 minutes to do the swap..........
Lee
JDM Civic Hatch
