Will the BOSH/FORD Red Top Injectors work with the s/c reflash for 00-02 2.4L ?
Or can I put any 310cc injectors that will fit on that engine?
whtas the flow of those red tops? And what model of fords do they come out of?
Nate
1995 Cavalier W/2k1 Engine
Red tops I believe are 330cc injectors..........................
with the GM reflash or the RSM relfash they should be able to idle just fine ...............
since both flashes back off injectors at idle......................
Lee
JDM Civic Hatch
The gm s/c reflash can handle a 15% difference in 310cc injection. Meaning, it will support injectors between 263.5cc and 356.5cc. If you go any higher or lower, the ecu cannot control them properly.
I will NEVER change my sig. HTML 4 EVA!!
C24s/c wrote:whtas the flow of those red tops? And what model of fords do they come out of?
Nate
ford thunderbird supercoupe with the 3.8l v6 supercharged
will the reflash work with brown top injectors
^^^^^^ not ....
those are something like 380cc....... too large for the reflash to handle.....
red tops are good for something like 240bhp.........
Lee
JDM Civic Hatch
I had the red tops in my Z......... worked pretty spiffy for me.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
^running his red tops with reflash
