i just got done turboing my car about 2 weeks ago! and i have not put a filter on the turbo yet because i have to relocate my A/C lines and radiator reservoir so is there anything i can put there for the mean time?
lol um uh a filter still? just stick one on the end?
96 Camaro A4 383 12.5:1, E85, Full suspension, Nitrous outlet plate kit, hooker headers and catback, 3800 circle D converter.
2002 Silverado LQ4 6.0 CAI, Long tube headers, 4" exhaust
1996 s10- 97 ECU and wiring, soon to be boosted daily driver.
^ Doesn't always fit like that, I think you might have problems if you have it right there, unless you don't have A/C.
For the time being, mine has a screen over the inlet, I need to put a pipe on there and run it to a filter, someday.
The McGuyver way:
One medium sized rubber band, approx. diameter of the turbo inlet.
One pair of nylon pantyhose.
Stick of plain bubblegum
Cut the pantyhose so you have a small tube like sock, wrap around compressor inlet and secure with rubber band.
The bubblegum is to chew while you do this, it is NOT optional.
Actually I don't think this is a good idea, the nylon would probably melt with the high underhood temps......but it sounded good.
Do what shifted did and put some kinda screen over the inlet....or stay up all night fixing the A/C lines and install a proper air filter. It is no fun to blow a motor because you suck up something that your motor can't digest and make power off of, like say a beetle, rock, marmot, small infant, etc.
Good Luck!
1988 Pontiac Fiero, engine transplant underway.
2004 ECOtec, built and boosted
Small infant
that screen was my idea he he....
Shifted wrote:^ Doesn't always fit like that, I think you might have problems if you have it right there, unless you don't have A/C.
the engine he posted is a 2.2, only thing that would get in the way of that filter is i would say the battery, but yeah on a 2.4 it would be an extremly tight fit
^^yep ur right, but i have about 3/4" clearance between the battery, it does what i need it to do. I never checked to see what motor his had, nor did i know about the problem with the a/c lines. But considering the only thing ive ever boosted is my car, i hope you guys can forgive me for not knowing
Emry
yeah the a/c lines have a way of getting in the way, thats why im ripping them out
i already removed the clutch pulley cuz it was loud and clanking
