Ok, i just called hahn to order all the parts i need for the oil return on my ecotec and the parts tech wasnt in. Does anyone know what im going to need for the oil return. I know a fitting for the oil pan but what about the line from the turbo to the pan.(braided?)
my return line is a braided steel line
return line just needs to be a oil proof hose basically because there shouldn't be much pressure.
5K PB: 24:50
10K PB: 54:26
Am i right by saying the size of the line should be a -10 AN? Also does anyone have a good website with the fitting that i can use to tap into the oil pan instead of buying the whole kit from hahn. So all i need is a -10 AN line and a fitting that has a -10AN end and threads to tap into the oil pan?
for $100 the kit from Hahn isn't a bad buy TBH. It has everything you need in exactly the right lengths and sizes.
5K PB: 24:50
10K PB: 54:26
