is anyone here running a custom turbo setup? i read the faq above saying that you can build your own. so i was just wondering if anyone here has done that. and how much it costed.
JBO'S Mr. 64.....
ya MANY MANY MANY people have done custom turbo set ups............
Check out my Car domain site below for a whole WACK of pics .........
Lee
JDM Civic Hatch
around how much your custom setup cost those who did there own?
JBO'S Mr. 64.....
Shifted wrote:$3500ish... parts list is in my registry
around there ...........3500............. but that isn't a junk yard turbo kit .......... thats all nice mandrel bent, Garrett .....etc......
Lee
JDM Civic Hatch
the more i see the prices the more i think ill go nitrous
JBO'S Mr. 64.....
YOu could through together a Junk yard kit for like 1000
Check out Ken 2.2................... He spent like 1500 I think or under .... and his set up is really clean and really nice !!!
Lee
JDM Civic Hatch
i got just the basics right now on my 2.4 with intercooler for right around 1200. but i am only running 6 psi right now and i got to get a few more things for tuning it and then it will be set.. so probalby 2000 most when i get it all said and done.
-- MyZcar
I'm not sure if its the installation or the maintenance that is more expensive. I've been running 7 psi for about 4 months and I have went through two AFPR's and a fuel pump. Not to mention all the headaches due to my exhaust leak(s), wastegate continually getting stuck open and having to run premium gas.....
Boosted Eco @7psi for now....GTO come spring.....
Like Lee said, there are MANY people on the Org running custom turbo setups. Check out the Boosted J-Body List floating around the boost forum, it'll give you a good idea who has what.
As for cost, it all depends on how much money you have, what deals you'll get, what sales you'll find, etc.; prices always vary. I've seen prices varying from $1000 to $4000, so its all up to you.
Blown.
You COULD put together a junkyard setup for under $2000. But...not the best level of tuning with just an FMU and FPR.
sort off topic... but what WOULD be the best method of tuning? I was thinking megasquirt edis...
2004 Cavalier
13.2@105........
Mods...
BFG Drag Radials
Saab Turbo kit
2.5 exhaust, w/cutout
Spec Stage 2+ Clutch
Mr.64 (Shaune Drake) wrote:the more i see the prices the more i think ill go nitrous
You can build a turbo kit for around 2300 for a garrett t3/t4 from www.agpturbo.com you can also get your hks bov or whatever you want from their along with flanges from the turbo kit. You can all the bends, couplers, oil lines, and clamps you need from ebay. Email me ill put together some links if you want. Or you can buy a hahn kit from this link [URL=www.ryne.com/storefront]Hypsy store[/URL]
*2012 mazdaspeed3*
yeah that link didnt work
*2012 mazdaspeed3*
ECOTEC wrote:sort off topic... but what WOULD be the best method of tuning? I was thinking megasquirt edis...
FMU and FPR < E-manage < Megasquirt. Each are harder to installer, but the Megasquirt is very simple to tune and has a higher tuning capability than the E-manage. Cheaper also.
Spotabee Racing (The Fake Z24) wrote:ECOTEC wrote:sort off topic... but what WOULD be the best method of tuning? I was thinking megasquirt edis...
Correct me if i'm wrong ...... but does Megasquirt have an "AUTO TUNE" feature......... that it automatically changes the parameters to fit a preset desired AFR................
I thought I read that somewhere on here at one point ........
Lee
JDM Civic Hatch
can you please send me link to where i can get a megasquirt? and is there different ones?
thanks
nick renaud wrote:can you please send me link to where i can get a megasquirt? and is there different ones?
thanks
http://www.diyautotune.com. They sell assembled Megasquirt 2 kits for a very fair price, the BEST way to go IMO if you don't want to deal with assembly and soldering.
Megasquirt has a sort of autotune feature. Theres a few software apps that will allow you to take a datalog and analize it based on a desired AFR map and the software makes all the recomended adjustments. You then just load in the new fuel map and datalog agin to get it closer.
Theres also support in the MS&Spark code to have AFR targets too but thoes are not intended to replace a good base map, there more so to compliment it.
<img src=http://home.comcast.net/~richnj221/smiley.gif>
Yea. The "Autotune" is more for a baseline tune that you then fine tune to a more accurate extent.
