i was able to get a pioneer sub out of a cobalt at work and im wondering how to hook it up.i want to put it with a 1000 watt amp.i have a stock head unit so i when a got a loc. my bigest problem is when i tap the rear speaker to istal the loc which wires do the black and gray go to? the 6x9 has 4 wires going in, teal blue, light blue and something else.
what model sub is it? You most likely don't need anywhere near 1000w rms.
In my family we teach that boys have a God-stick and girls have a Shame Cave. -John Stewart
got this form here
http://www.pioneerelectronics.com/chevy/Index.html
10" Dual Voice Coil High Excursion Subwoofer for higher output and less distortion. This subwoofer operates using a dual voice coil in a 2-Ohm load, to produce clean deep bass response for all types of music. The woofer also incorporates the latest speaker cone technology called Pioneer IMPP (Injection Molded Poly Propylene) to prevent the speaker cone from flexing or breaking up. This results in smoother output. In addition it has a bumped back plate for longer woofer movement. The subwoofer will not bottom out, and has higher output capabilities compared to standard subwoofers.
the only reason for the 1000 watt amp is because i have it laying around.could i just extend the wires from one of the speakers and pulg it in to the sub?it has the same type of connector as the 6x9s but with 2 red and 2 black wire
Do you have a Monsoon stereo? Because it sounds like it since you have 4 wires per speaker.
it has a amp in the drivers side trunk but the system doesn't play mp3.i bought the car used and the finish is worn off so i really dont k.now.is there another away to find out?
