hey guys .. is there eny posible way to wire up a cavalier gauge cluster in a sunfire on the sunfire harness ? to cut and splice
if you get same year as your car, it should be a direct plug-in. Peice for peice. At least i think so, I might be wrong, but I'm pretty sure.
Faith is to believe what you do not see; the reward of this faith is to see what you believe.
-Saint Augustine
On the 95-99 cars, you need to re-pin the connector when swapping between a Sunfire and Cavalier. And you'll have to do a Passlock re-learn, but that's easy (and the how-to is in the FAQ).
