I am planning on getting some dynomat for my cavi. I want to do the whole trunk (lid too), the floor boards, doors, rear quarter, the roofand the license plate. I am looking on ikesound.com and i cant figure out what size sheets i need and how many. If there is another post about it.. can you please redirect.. Thanks
100 sq/ft should do you justice.
100 sq/ft now is that with room to screw up? lol. What all else do i need to get with it. Also i was wonderin if anyone knows if they sell wire tracks or wire guides anywhere (i cant really explain what they are without showin a pic..and i forgot where i saw the pic at) or is there enough space to run lots of cables under the door jamb things?
And then some. I did my trunk, doors, roof, and under the seats with that and had extra. You should/probably will get a lil roller that comes with just about any kit you get.
the razor and the lil roller thing were junk that came with my kit. i did my whole trunk and deck lid with like 50 sq. feet. as far as application make sure its cleen i cut the @!#$ out of my fingers several times while putting it on and the roller doesnt work so i got some gloves and went from there
i'd get 150 square feet. Double up on important areas like the doors and the trunk area. I have 150 square feet of fatmat down, and am planning another 50 square feet.
well your gonna spend near a grand on that much dynamat, pic one of the other brands, they are better and cheaper.
..lol fatmat
i got like 120 square feet for like 120.00 shipped sure this will turn in to a bunch of opinions on different kinds now tho
So dynomat = Mucho dollars. that sux. guess i can look into fat mat. Do you cover up the little holes the pegs for your panels go into (the ones that hold the door panels to the door) and then just cut a little section out for the pegs to go thru?
Is there another brand other than Dynomat that is just as good, but not so expensive? Also, is there a right-up somewhere here on how and where to apply it?
____________________________________________________
2002 2.2L -Base Model- (not for long) Black Cavalier
There are some install guides on dynamats site
here
theres
fatmat
dynamat
deadmat
brownbread i think is one
i just bought 100 sq ft of fatmat for like $120 shipped on ebay. comes with a lil install kit
i used fatmat, and i have no complaints.
Haron wrote:do u really need that @!#$??
what are you reffering to?
