I have a "sealed" encloser that is 3" high..38" long..and 34" wide..utilizing my spare tire well with air space..with two 12" almani subs and two 1100 watt amps..its weird though..dont know if it cause its sealed to the body or what..but the entire car shakes soo bad when it hits that it feels like the car is missing and the stearing wheel is hard to control and the pedels like have a mind of there own..is this common with enclosers like this?
Elmer the wricer hunter..."Shhh be vewy vewy quiet...I'm huntin wrice"
Kill da wriiiicer...Kill da Wricerrrrr..kill daaa wriccceeerr!!!
3" high??
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
yeah but it is around the spare tire well sqare
damn it ill just take sum pics tomorow..and you guys can see what im working with
<img src="http://memimage.cardomain.net/member_images/1/web/1849000-1849999/1849637_4.jpg">
<img src="http://memimage.cardomain.net/member_images/1/web/1849000-1849999/1849637_5.jpg">
<img src="http://memimage.cardomain.net/member_images/1/web/1849000-1849999/1849637_3.jpg">
its 38" x 36" x 3"..centered over spare tire well..trying to figure it out
2 12's..one 1500 watt amp..getting another 1200 watt next week..but need to figure this out though
so it's only 3" high..your subs must be what, like 2.5" mounting depth?
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
no the sub is like 8" mounting depth..there actually-mounted on the top over the spare wheel well....the box is around the empty spare wheel well like 3 inches on each side
one more thing..it seem to respond to low bass alot better then tight bass..example..three six mafia..low bass songs..@!#$in very loud..eminim..doesnt hit very hard..just seems like low bass..and its sealed not ported
does it mean there may be too much air space?
I know what you did... and I bet the reason why your subs sound like that is because you aren't completely sealed... You need to go back and screw that wood down to your car and then run silicone all over all the seams.. going overboard here will be a good thing..
I bet your very close to running those subs near free air which is not good at all.. also make sure you check your amps crossover and gain to make sure they are set correctly
well guys..i had an experenced intaller look at it today..he has built alot of comp systems around this area..he said yes..it was around 5-6cuft..and told me it was sealed perfect which he said was suprizing cuz its hard to do ..but it was sealed..and said to put 2 4"x11" ports in the box and it will solve the problem and the rattling..also to put dyno mat inside the box..if not all over the trunk..but what was really needed was the ports..he said after mearsuring stuff..that he was shocked cuz ported to what he said..my box i built was like .003 from being the perfect ported space for the subs..ill port it and take sum more pics
