I wasn't really sure where to put this post so i figured electronics would be the best place. I just bought a Greddy E-manage set up from a friend of mine but he has no wiring instructions...it's the older model that's just the little blue box with the one wiring harness coming out. Anyways my question was if anyone has the same set up and if they knew the wiring diagram on the unit itself and where to run them to the cavalier harness.
There are a ton of posts about emanage in the boost forum. Also, check out the ny j-bodies homepage. They have a walk thru for emanage installation on an eco, not sure what you have because your registry is empty. They also have the pinouts which are essential when wiring things up. Even if you don't have an Ecotec, still print the walk thru off....it will help quite a bit. When I wired in my SAFC-2, I used the walk thru for a different engine to guide me. Good luck!
I think theres diagrams on the NY J-bodys site
Thanks for the info guys , i'll check into those.
