Positive and Negative Rears - Audio & Electronics Forum
Saturday, May 07, 2005 12:41 PM
I got some new speakers for the rear, and i dont' know what wires to hook up and where to hook them, 4 wires for the stock speakers and 2 for the aftermarket ones, please help this audio/electronic newbie, thanks~!
"Sink or Swim, Do or Die!"
Re: Positive and Negative Rears
Sunday, May 08, 2005 1:54 PM
You have the optional amplified rear speakers... best to bypass the amp (driver's side of the trunk, behind the carpet) and run the speaker lines direct to the new speakers instead.
I don't know what the output is like bypassing the amp tho.. you may want to consider an aftermarket amp to power them.
<a href="http://www.lenkorules.com/"><img src="http://s93165229.onlinehome.us/images/zm/sig/LRDCsig3.jpg"></a>
Sunday, May 08, 2005 2:08 PM
For now i just used 2 of the plugs from the 4 slot to supply signal because
output sucked of my aftermarket deck doin 50X4. I just got a amp and am
gonna grab some front speakers 6 1/2's =) real soon. So i would suggest
you look into an amp. running it off the factory amp you lose some of
the sound and you can tell.
Sunday, May 08, 2005 3:09 PM
if you are using an aftermarket deck..there is no need to bypass the factory amp. you can use two wires(don't remember which ones, can't find my pics i took ) but you can just use 2 of the four and it'll work fine.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
