led wiring.. - Audio & Electronics Forum
led wiring..
Friday, May 06, 2005 10:31 AM
ok i ordered some leds from lsdiodes..they are the blueones that run the best off about 3 volts...now from what i can tell if i wire 4 of them in series i will get 3 volts to everey one correct? The thing i am unsure of is what resistor to use when i wire them in parallel..Do i use the same resistor for all of them? and can i put as many as id like in a row? if someone can tell me what resistor to use that would be the best...here is a link to the ones i got: http://lsdiodes.com/5mm/
and again i got the blue ones..phil
Re: led wiring..
Saturday, May 07, 2005 7:35 AM
If you wire 4 in series, that'll give you 12 volt for the 4, and it should work like that without a resistor.
Beat it like it owes you money
Re: led wiring..
Saturday, May 07, 2005 8:41 AM
umm that doesnt make sence according to the lsdiodes tutorial its
volts over leds..so 12 volts over 4 leds would be:12divided by 4 gives you 3...that is right ??but i want to know if i can do parallel and what resistors do i have to put on the feet of my leds to get it down to about 3v?...phil
Re: led wiring..
Saturday, May 07, 2005 5:07 PM
If you do parallel you will need resistors. If you do series you will not.
So why not do it in series? Easier, cheaper, more reliable.
-- The The One One --
<IMG SRC="http://registry.gmenthusiast.com/images/neo32843/personal_pic.gif">
Re: led wiring..
Saturday, May 07, 2005 6:44 PM
Can i put as many strings of four as i want together?? that i can have 12 leds come on with one switch but have 3 strings comming off the same switch?phil
Re: led wiring..
Saturday, May 07, 2005 9:15 PM
Make all the 4-LED series cucuits you want, then wire those in parellel...
Re: led wiring..
Saturday, May 07, 2005 9:22 PM
Your theory that "If 1 LED=3v, 4 LEDS=12v" is not entirely true. Experiment some, you may find that you can run strings of 3 LEDs rather then 4. Not exactly sure why, probably something to do with the amount of load on the curcuit, but it isnt a linear relation like that.
So like I said, experiment. You may need strings of 3 so they are nright enough, or maybe even strings of 5 so they dont blow. Coudld go either way. Id say start with 4 and use your judgement to determine if they are too dim. If so, try a string of 3 instead of 4.
Also, I didn't include a switch on my diagram up there ^^^ but you can hopefully figure that out.
Re: led wiring..
Sunday, May 08, 2005 1:49 AM
You also made the LEDs backward
<img src=http://img.photobucket.com/albums/v502/brad_sk88/SpringSig.jpg>
Re: led wiring..
Sunday, May 08, 2005 1:50 AM
oop, nevermind
Re: led wiring..
Sunday, May 08, 2005 3:17 PM
My LEDs are jsut fine lol. Loser.
Re: led wiring..
Sunday, May 08, 2005 3:23 PM
It's funny that LEDs are designed opposite of their schematic symbol
Re: led wiring..
Sunday, May 08, 2005 5:06 PM
ok i wired four together and they are pretty bright and id like to make sure the voltage is down so they last a long time..lol..anyways what size of wire shouls i use when i wire them in for good? When i did a test string i used 16 and it was not too easy..would 22 be better? also any time limit on how long these things can be on? thanks for the help guys!..phil
Re: led wiring..
Sunday, May 08, 2005 6:43 PM
I dont know what gauage... but...
WIRE SIZE >OR= LED LEAD SIZE
And you're good.
Re: led wiring..
Monday, May 09, 2005 4:02 PM
No time limit unless you have overvoltage.
Re: led wiring..
Tuesday, May 10, 2005 12:23 PM
How many leds do you guys have in each vent..i wa thinking one each but maybe 2???phil
Re: led wiring..
Tuesday, May 10, 2005 7:23 PM
^^ All depens on what you get. Different voltages, amperages... etc etc etc... Just get some and try em out.
Re: led wiring..
Tuesday, May 10, 2005 7:31 PM
I have one each, it works fine, unless your LEDs are dim.
