starter kill wire + tach - Audio & Electronics Forum
Monday, May 02, 2005 7:43 AM
hey, anyone know where the starter KILL wire is?
also l looked in many guides and they say the tach wire is WHITE and in some guides that its PURPLE/WHITE.
<a href="http://www.whiteboy.ca"><img src="http://www.whiteboy.ca/images/whiteboysig.jpg" border="0" target="_blank">
Re: starter kill wire + tach
Monday, May 02, 2005 9:09 AM
starter kill wire? you use a relay to get the starter kill feature.
Monday, May 02, 2005 10:12 AM
The starter wire in your car is yellow.... Its in the ign. harness.
There is no factory starter kill like mentioned above. The starter wire is basically cut and ran through a relay to add that feature.
The tach wire is purple w/ white stripe- located in the engine harness.
The engine harness is found next to the battery, below the radiator hose, just above the transaxle.
<img src=http://www.consumptionjunction.com/i/default03.gif>
